By-pass cig-lighter switch?
Touché. My question should be more sophositcacted then: By tapping into the radio feed to run an Iphone and Jabra wireless charger do I risk the wrath of Kirchoff's laws by pulling too many amps and hence frying a "too touchy" MB designed radio?
1 Post
95' AMG SeeThreeSix
Only thing that can fry is the fuse, as that is the only part of the wiring that will supply full current to the devices until the current be branched off to its corresponding loads (chargers, radio, ect.) I hope that makes sense.
By tapping into the 12V radio feed you are essentially creating a parallel circuit. Amperage thus branches off into each load accordingly while voltage stays the same. In a series circuit voltage drops off while the current is constant through the circuit, thus in series would you have to worry about pulling to much amperage "through" the radio so to speak. Should not have any issues tapping into ANY switched 12V source whether it be the radio feed or any others. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
1 Post
95' AMG SeeThreeSix
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
