Spark Plug Change
https://mbworld.org/forums/c36-amg-c...deos-w202.html
Will be simpler to remove the washer fluid reservoir. I recommend you get some good tools and several extension bars. Don't drop the tools unless you want to take of the under engine protection. ALWAYS remove you plugs on a stone cold engine and torque up new plugs correctly. I would recommend also a change of cables at the same time. Magnecor make THE best cables. Choose the KV85 type.
Go check also the FAQ's and tech info here for example: http://www.ngksparkplugs.com/
What type plugs (x16) are you going to install??
