Thickness of swaybars
H&R swaybar for front/rear are 28mm and 18mm.
Is it the same thickness on factory swaybars?
Is there a good reason buying the H&R swaybar?
anyone made this improvent buy?
I upgraded to a custom 22mm rear bar and I'm going to fit a 32mm front bar when I get some time. The rear bar made a bit or a difference and i think in conjuction with a bigger front it'll be much better.
plz advise as it will gr8tly help me follow suit
thnx
if H&R is similar to factory stuff, then I guess it's a worthless upgrade.
there was a guy on this forum many years ago, I think it was RemoLexi putting an ML AMG swaybar on his C43, but there was never an update info of how it worked out?
did u measure the stocks? cause i have measured them on both a c43 and c36 and the r 27mm front and 16 mm rear and attached is the offical Merc spec of the 36AMG
ps: how much did the bars cost you, and can another set be made and shipped?
