Will these rears fit my car?
Old Jan 13, 2011 | 09:46 PM
austinholloman's Avatar
W203 C55 and SAAB 9-3 2.0T
I have 18x8.5's all around but I been looking for the same wheels with a lip in the rear. These are huge in the rear though 18x10!!!
http://cgi.ebay.com/ebaymotors/18-ME...Q5fAccessories
Old Jan 13, 2011 | 10:06 PM
tasho3's Avatar
2014 C63 Sedan
They look sick!
Old Jan 13, 2011 | 10:25 PM
I KNOW!!!! But will the freaking fit???
Old Jan 13, 2011 | 10:30 PM
2PHAST's Avatar
500E Signal Rot
Those S class wheels use 14mm lugs and they are not hub centric to a W202, so you would need hub centric rings. Really isn't a fix that I know of for the lug problem. You run the risk of experiencing vibration and/or weird noises due to the lug difference but I think that problem would be minimized if you did have the hub centric rings.
Old Jan 13, 2011 | 10:31 PM
And another dream shot down!
Old Jan 13, 2011 | 11:12 PM
Outlawlatemodel's Avatar
2006 c230
the only thing that will cause a vibration is not having hub centric rings which all newer style wheels have because so many wheels will fit so many different style cars, the 14mm verses 12 means nilch will not cause a vibration, it will be more important to know whether they are ball seat or conical seat. MBZ and all german cars are hub centric not lug centric
the biggest trick will be to get the wheel in the right location, if you could get the 10 in the rear i think we are talking 30mm range on the rear offset, i believe the 8.5 fronts should be in the 32mm range regardless you are using spacers all the way around,
the biggest risk is getting the 10 to fit no idea, i have sold wheels for many many years, on the 14mm lug many audis use 14mm and a after market wheel for a audi is the same as a mbz with same bolt pattern/offset
