Rolling my rear fender?
btw eastwood products has a fender rolling tool
i did the left to right portion i did not go up and down
no need your lips should be rolled
One of the things I've learned with K-Mac is that they put some serious thought into how they make their camber adjusters, wherever possible working it so it's to the typical owner's advantage.
Next you need to find a new solution to fix the rear bumper.
I solved it with welding a screw onto the back of the fenders where I can mount the bumper.
It's plain to see that pulling the bottom of the wheel inwards is the better way to go, make clearance rather than destroy it.
That's why the K-Mac kits for these cars are made that way. Save you the trouble of rolling and cutting and at the same time replace bushes which you would need to replace anyway. They're also more accessible for adjustment on the aligner and allow you to get whatever camber setting you want.
