OIL LEAKAGE ON C36
Old Apr 18, 2011 | 03:24 AM
hktox's Avatar
C36
OIL LEAKAGE ON C36
IS THAT A COMMON PROBLEM OF OIL LEAKAGE ON C36 OR ALL M104 ?
I FOUND THE BIGGEST PROBLEM IS LEFT-UPPER CONER, THE OIL IS FALLING AND MELTING ON THE EXHAUST.
ANY SOLUTION TO SOLVE IT?
THANKS!!
Old Apr 18, 2011 | 03:41 AM
DRBC43AMG's Avatar
Must be a leaking gasket there. Any pipes around or nuts which could be a little loose? Check it out.
Old Apr 18, 2011 | 05:33 AM
hktox's Avatar
C36
THANKS FOR REPLY,
I HAD CHANGED THE GASKET 1 YEAR AGO, AND FOUND THE PROBLEM AFTER 3 MONTHS, MY TECHNICIAN EXPLAIN THAT MAYBE THE VALVE COVER HAS BEEN DISTORTED.
