Finally got my import camber arms
Old Jun 2, 2015 | 11:00 AM
  #51
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
Have a friend "bounce" the rear end of your car while you're in a position to listen. I spent two weeks chasing down a similar sound on my wife's E class to find that it was the exhaust. One of the rubber bands that secures the muffler had disappeared, so when cold the muffler would tap the undercarriage. Once it warmed it wouldn't. My guess is the expansion from the heat changed the behavior.
Anyway, the point is that it could be something other than the wheels/tires/brakes/linkages.
On the vacuum hose, I busted my front passenger "L" connecter. I fixed it with a small insert and some shrink tubing. At the age of these cars the hoses are so brittle you'll never get them to fit over one of the OEM connectors.
Old Jun 2, 2015 | 12:12 PM
  #52
KJI3jflarryfe93's Avatar
i will have to lift the car to check under it what might be wrong?
my exhaust is on the drivers side, my flat tire sound sounds like coming from the rear right side?
this tuk tuk flat tire noise is driving me krayzee for the first 5 minutes, sounds like something is slamming inside my right side rear inner wheelarch.
then the noise goes away.
Old Jun 11, 2015 | 05:05 PM
  #53
Boost_or_die's Avatar
98 C43,99 gsxr 750
Have you checked to make sure the drive shaft isn't bumping anything?
Old Jun 12, 2015 | 01:31 AM
  #54
i had my car on service in april, my tech güru would have told me if soemthing is out of whack?
maybe my hand/footbrake internal hub parts might be the culprit or the lower hub bushing which sits behind the dust plate??
i can't think of anything else
Old Jun 12, 2015 | 10:07 AM
  #55
DRBC43AMG's Avatar
Perhaps it's a Troll wanting to back to the forest...
Old Jun 15, 2015 | 04:21 PM
  #56
98 C43,99 gsxr 750
It's tough to say without hearing it in person and being able to check it out. If you want to buy the plane tickets, I'll gladly come help! Hahaha!
Old Jun 16, 2015 | 04:14 AM
  #57
i might take you up on that?
i'll let my Güru take a peek first, maybe it's one of the bushes or something else?
Old Oct 16, 2015 | 11:38 AM
  #58
I emailed MB Arts for new rose joints as I think mines are worn out?
I get a knocking sound on n off which bugs the crap out of me.
I still haven't got any reply from MB Arts!!
Do any of you know if this shop is still in biniz or is it out of biniz?
I need new rod ends for next summer season.
