Issue with Dashboard and Starting-Advice Needed
Old Feb 13, 2012 | 08:17 PM
morganb's Avatar
C63 AMG, C36 AMG, SL500
Question Issue with Dashboard and Starting-Advice Needed
I have an electrical Gremlin at the moment.
The car has been unhappy to start, it cranks over slowly when trying to start.
Sometimes when it starts and runs all is fine.
Yesterday the gauges did not work properly. Fuel showed empty with fuel light on and no speedo. Stopped and started again and all was normal.
Anyone had anything like this?
The battery seems a little flat as its turning over slowly, I cannot imagine this would cause the symptons above.
Any ideas on what might cause this?
Old Feb 13, 2012 | 11:52 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
The battery could cause all of the symptoms you mentioned, get it checked.
Old Feb 14, 2012 | 12:49 AM
cm60k's Avatar
What kind of Battery you have..?, it should be NOT less than 74AMP,, and also check the Alternator......
ZAYED,,
Old Feb 14, 2012 | 12:55 AM
morganb's Avatar
Thanks guys, cars going in for a new Head Gasket on the weekend so hoping only a battery to repair this.
