New engine or fix bad headgasket??
Mechanic says it will cost $2,200 for both heads, including having them milled checked etc...
Would it be better to put in a C55 engine? Where can I find one? I searched but didn't get much.
Thanks in advance.
Leak/pressure test and mechanic used that blue fluid that changes color if somethings wrong. It passed, pressure held and blue color stayed blue.
No external leaks at all. Checked everything including heater core.
The oil and trans oil had no signs of coolent. Everything checked out good.
There is some white smoke coming out from the tail pipe.
But it doesnt have a sweet smell to it. It smells more like the car is running rich or something in those lines?
How can i check if there is a leak in my oil cooler? Im going to check out the thread you mentiioned, thanks for that.
Btw, the car runs great, no shakes nothing. But im loosing coolant from the top of the resovoir to bottom in a 30-50 minute drive. The faster i drive it the faster the coolent goes down.
Today i no longer have the white smoke coming out of my tail pipe. AND the coolant is not going down as fast??? So weird!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
I would be changing the radiator cap regardless, they are very cheap and if they don't hold the full 15psi then the coolant level will drop without a visible leak.
Once it gets low in the bottle does it continue to drop if you dont top it up? if it doesn't keep dropping then it may just be a weak cap and/or being slightly over full.
ZAYED,,
Ausmbtech, i usually fill the resavoir to the top when its low. I will let it sit 1/2 next time to see if it will stay there.
Thanks guys!
These engines like to work with a certain pressure and don't forget as it is an AMG, it deserves only the best, so I wouldn't go for cheaper imitations
