C43 stalling and hard starting problem
Hey guys,
Newbie here, i have a c43 with a weird problem. Car stalls and won't start till about after an hour or so... Replaced the following.. Cps, k40 relay, fuel pump and fuel filter. Car still stalls. Fault code sometimes show cps but it has been replaced twice. Help!!!
Hi
Was it a OEM CPS ?
Mine had exactly the same problem, tried an after market CPS which after fitting still displayed a similar stalling problem... bought a OEM CPS replacement all fixed.
But to make sure as mentioned Star it... My experience with sensors/filters is buy cheap buy twice.
Was it a OEM CPS ?
00 C200 & 00 C55 & 06 SLK55
You may have a bad or dirty Injectors, or a high pressure in the fuel rail, you must to measure it , it should be NOT higher than 3.8 bar
(as i know).........![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
ZAYED,,
ZAYED,,
1999 MB C43 AMG
If it was the injectors going bad, you could try a very cheap solution that might help. Buy some Techron (think people call it seafoam) to clean your injectors. I had a pretty rough idle and some hesitation when accelerating. I put a bottle (for 20 gallons fuel tank) in my tank when empty and filled it up when fuel, repeat 3 times and it might improve.
This a very cheap solution before looking at more expensive fix/repairs.
