c43 leaking oil.
Old May 16, 2012 | 04:15 PM
AwalBenz's Avatar
2013 G550, 09 Audi R8, 01 E55 AMG
c43 leaking oil.
Looks like my c43 is leaking oil and so i checked underneath and there seems to be a hole in the oil pan....now the car needs an oil change...obviously i must drain out all the oil in order to take the oil pan out and replace it right?
Old May 16, 2012 | 04:42 PM
DRBC43AMG's Avatar
Right on the nail. How comes u have a hole in the pump,?
Old May 17, 2012 | 05:23 PM
AwalBenz's Avatar
i have no idea where the leak is coming from....i will post a picture but is it complicated taking the oil pan out?
Old May 18, 2012 | 04:07 AM
DRBC43AMG's Avatar
I don't think it is a DIY job, not unless you know what to do if you pull or snap a stud/bolt and how to repair it. Also, the sump and gasket area it must be cleaned perfectely then torqued to specs. Are you sure it's not an oil cooling pipe or the oil filter gaskets on the left of the oil filler cap area?
