tried searching, how do you change the instrument gauge bulbs? some blew out
1.) pull steering wheel out as far as it can go
2.) push modified coat hanger in between the cluster and the dash
3.) turn the hanger and pull
4.) use a pair of needle nose pliers to twist the bulbs
install in the reverse
Here is a video:
You do not need to pull the steering wheel but it does make it easier.
no need to pull the Steering wheel,, Im always pull out the Cluster without pulling the Steering wheel,, just using the Hooks to pull it out,,
MB Hooks #: "140 589 02 33/00"
ZAYED,,
If pull is remove the steering wheel, then be very careful not to get a bloody noise with an exploding air bag
Some say (on the UK forums) that removal is greatly facilitated by removing the under dash upholstery and pushing the instrument cluster from behind.
I purchased my cluster hooks from here: http://mbspecialist.com/mercedes_web...8-050/KA-2403/
a good way is to remove bottom cover and push the cluster out from underneath the pedals.
if you suspect your cluster sits tight and you have to push hard, put a pillow on the backside of steering wheel as a protective not damaging your cluster when it pops out.
