C43 Rear bad creaking noise when going over bumps???
Poly bushing comes as an aftermarket product, not coming as a genuine part,
https://mbworld.org/forums/c36-amg-c...mselves-2.html
http://www.ebay.com/itm/597C-Mercede...-/180864711411
http://store.lpdautoparts.com/9401--...029401202.html
ZAYED,,
this kit does it come as a 2 bushing kit for one side?
the smaller poly bushing on the right side seen in Ebay auction, this smaller poly bushing does it replace factory outer side 2 piece bushing?
I want the Kmacs, but my wallet is in pain. I'm also going to need rims eventually...
i am very happy
pads front #1 and rear #4, I have no rub so far
car is a lot better now than when it was new, handling feels planted and has great stability
highly recommended
k-mac's will give you squeeks that's what other people say, do you really want squeeks?
i don't think you want that.
tirewear is now peffect across the tread!
also new complete kit front/rear suspension arms.
i now have a new car feel!
if you can afford?
replace all bad parts.
you can't swap half of the suspension and then expect a wow factor, you need to go all the way to obtain full synergy between suspension parts.
when i only had my camber arms installed before doing the complete suspension overhaul, car drove like hogshieeeet above a certain speed, i didn't like it!
with all new parts fitted she now rides like a dream.
1½ month left for 2014 spring premiere for my car to see the nasty roads in my country
Like any suspension connection only if a nut or bolt is loose.
The unique K-MAC patented design adjustable kits to suit Mercedes models now feature a locking device where it is impossible for a nut to become loose.
K-MAC have been designing, manufacturing bushes now for 50 years with this particular rear adjustable bush design dating back 19 and therefore well and truly proven.
Squeaks come through metal to metal contact. This is prevented with K-MAC bushes being elastomer to absorb impact loads and the only design to incorporate hardened steel and nickel chromed centre bushes for longevity.
With K-MAC you fix it right the first time!
The major advantages over spherical bearing/multi link arms:
1. K-MAC kits precisely adjust the lower arms inward to reduce costly, premature inner edge tire wear and improve traction.
While multi link arms move top of tire outwards decreasing tire to outer fender clearance.
2. Spherical bearings are rigid. Only having a paper thin PTFE or teflon lining. Nothing to absorb or cushion impact loads. Anyone in the race industry pointing out they soon pound out allowing metal to metal contact. Especially when used in day to day commuter use.
i only refer to what other had said.
i was going to buy kmac's before doing my suspension overhaul, but all negative feedback on this forum put me off!
noone wants to waste money on parts if they don't give satisfaction
but when i installed them in my C55, they started to squeaking after a month, also afraid if bodyshop installed them wrongly..!!
ZAYED,,
Yes with in-house manufacturing (which in industry today is becoming a rare event) not outsourcing we have total control over manufacture and rapid, ongoing upgrades is the norm.
The torqueing and secure locking of the nuts to prevent squeaks was resolved now close on one year ago.
K-MAC being the original designers/manufacturers of bolt on (no mods required) front and rear Camber, Caster, Toe adjuster kits to suit all Mercedes Models (so owners can return vehicle to factory specs) of course controversy is par for the course - not sitting on the fence, but going where others have not been.
I have other projects going on at the moment...
:vio lent:
