What the......
I noticed that the hex nut that you have to remove to remove the rotor was NOWHERE to be found, so it makes me think it's been missing for a while and the lug bolts were what was holding them in alignment. This would also mean that my calipers and wheels are basically all that is holding the discs to the car....
Now, I have spare hex nuts from the 36, but my question is: how to realign the holes. Do I just have to take off the caliper and disc? I'm not too familiar with how the 43's discs work: is there anything special you have to do to remove them as opposed to the simple two bolts on the 36s ATEs?
What a headache....
P.S. taking off the wheel to start work on the suspension was completely normal. No snags or abnormalities
What a headache....
Once the caliper is removed rotate the disc to align with the holes in the hub. I would suggest getting one of the alignment screws to make it easier to bolt back up but I would imagine you could do it without the alignment screw.
Thanks a lot 503. You're always here to help
When I buy new brake pads, a set of hex screws is always included in the package
