C36 Check engine analyzed, I just want to be sure (misfire)
C36 AMG 1996 black on black
Hi guys, so a few weeks ago, I came here because of a Misfire on my C36 1996 and I had a lot of help from you guys. But since my CE was on, I went to a garage to make it check.
So for now, the only code the CE showed, was the : Coolant Temperature Sensor.
could my misfire problem could be caused by this ?
Also : the guy at the garage, checked my Engine Wiring harness and my head gasket and both has been changed.
otherwise, I don't know what problem it could be.
Also, I don't have my car with me right now and I don't remember were is the sensor in the engine. Is there anyone that could show me a picture of the sensor ?
00 C200 & 00 C55 & 06 SLK55
If you have a bad Temperature Coolant Sensor, you should get a code: "P0115" malfunction of the ECT,, this sensor may send a wrong signals to the ECU,
that well cause some interrupted to the back ECU signals.......
*Temperature Coolant Sensor #:"011 542 51 17"
![C36 Check engine analyzed, I just want to be sure (misfire)-0115425117_fac_a8520097.jpg](https://mbworld.org/forums/attachments/c36-amg-c43-amg-w202/240825d1542237071t-c36-check-engine-analyzed-i-just-want-sure-misfire-0115425117_fac_a8520097.jpg)
ZAYED,,
ZAYED,,
