N/A 55 Swap Complete on my 1998 C43
Old Nov 22, 2012 | 07:54 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Originally Posted by Dziner82
It seems from some of the threads that a few of the guys that had this swap did most of the work themselves. I couldn't tell from your post did you have the shop do the swap for you or do you work there or something so that you didnt really pay a full shop price for the swap?
I have a connection with a guy that has swapped out a few engines before and has the necessary tools and space in his garage, he has never worked on a mercedes but he is my only option if i want to avoid shop prices. Does anyone have an estimate or know what a engine swap like this would cost if done at t shop with approx $80/hr labor rate?
paying over $1200 or so in labor on top of the cost of the engine would be the only thing holding me back.
To swap over just labor,depending on shop could cost 1200.00 to 1500.00 to do swap.
Old Nov 22, 2012 | 09:28 AM
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
Great thanks project55!
Old Nov 22, 2012 | 11:02 AM
ProjectC55's Avatar
Also the oil pan unless you have the engine from a CLK55 or E55 then it will not be necessary to change just drop it in.
Old Nov 22, 2012 | 06:56 PM
jarvis210's Avatar
1998 C43 w/ N/A 5.4l swap
the oil pan thing is the reason why i went with the 210 motor..... i didnt want to take my motor apart cause i am putting my old 43 motor into a freinds 208 430
Old Nov 23, 2012 | 06:17 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
I'd recommend using the EPC to compare oil pans. I believe the higher compression motors (W203, W209, R171) use the different oil pan. I have a 2001 S55 motor and I used the EPC to verify that the oil pans were the same.
Old Nov 23, 2012 | 07:56 PM
jarvis210's Avatar
the reason why the 203, 209 and 171 have different oil pans is cause the subframe requires different clearance than the 210,208,220. this is the reason why its much easier to use the motor out of a older car.
Old Dec 8, 2015 | 01:22 PM
  #32
AMG__POWER's Avatar
2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2025 glc300, 2025 e450
Hey I know this thread is from a while ago but how does the car run now? Is it ALOT faster? I am debating on whether to buy a c43 and do the swap
Old Dec 8, 2015 | 03:49 PM
  #33
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
there are like, dozens of threads here with other owners who have done this swap to their C43.
honestly, it's like half the reason to buy a C43.
one guy did other mods to his C43 with a 55 motor and was smoking stock w204 C63's
Old Dec 8, 2015 | 04:51 PM
  #34
AMG__Dom's Avatar
W202 C55 (5.4 swapped C43)
Awesome man! I plan on doing this swap in my 43 at the end of the month, would you recommend taking on the task myself using my buddys shop? doesnt seem like too hard of a job with the right equipment.
Old Dec 9, 2015 | 11:59 AM
  #35
Sulaco's Avatar
that all depends on your skills, tools, and shop. do you have an engine hoist?
there's a thread here with everything you need to know about how to DIY this job, including exactly which engines are a perfect fit.
I'm 75% sure I could pull it off on my own, but whenever I get around to it I'll just pay my trusted mechanic to do it for peace of mind.
it's the exact same engine as far as the engine bay and ECU are concerned, so there's no modifications needed except a water coolant inlet on the back of one of the heads. the only "challenge" is just the labor of pulling the engine and putting in the new one: removing accessories, etc.
I'd recommend a total refresh on the new motor before it goes in: gaskets, timing chain and guides (can't stress this enough, because it's like a $2k job if it needs it later)
