My C43 finally lowered...
Old Aug 11, 2003 | 03:51 PM
KWiK's Avatar
2002 C230 : 2007 C230
Originally posted by moedigga
My tech is going to put the camber bolts in during install aswell but that is front only
If your tech will let you, take some pics & document the camber bolt installation.
Old Aug 11, 2003 | 04:01 PM
99SlvrC43's Avatar
1998 Silver C43
just ordered 2 sets of #4 pads. Hope this gets it like kwiks!! My tech is going to put the camber bolts in during install aswell but that is front only. Silver if you are having bad problem with camber in rear after u put #4's in then try checking club202.com. There is a cat in that forum goes by the name speedybenz, he knows suspension. And is making some camber adjust kits for 202 that will solve are problems. About $250 a set.-MOE
Moe, Let me have the information on ording #4 pads for all four tires. Price and Part number. Did u get them from the dealer?
Old Aug 11, 2003 | 04:58 PM
moedigga's Avatar
2017 GLE 350 Wifey, 2005 C55 AMG
This morning I was with parts guy on his computer, i told him pad Size #'s and he plugged away. Then he says #2 is only pad for front but rear is available #2-#5. So I say well get me #3 for rear and we'll deal with 2 up front for now. Then I read yours and kwiks threads and was like uh-o!! I called him back and said get me 2 sets of #4 and we will make them fit. They are only 10 bucks aset no big deal. I dont have part # but dealer has all info on computer so they will know what you need. Hope this helps-MOE
Old Aug 11, 2003 | 05:40 PM
Eurosport's Avatar
monowiper
you guys going for Brabus springs because you don't want your car too low?
why not change your pads first to lowest possible and see how that looks like compared to stock, then see springs, could save you $$$ and get same look; from my understanding Brabus springs are not stiffer than stock AMG ones, i could be wrong though...
Old Aug 11, 2003 | 06:04 PM
99SlvrC43's Avatar
1998 Silver C43
Just made the call to the dealer, order 4 #4 pads $7.80 each. They are for the rear only, but lets see if we can fit them in the front also. will be here tomorrow.
Old Aug 11, 2003 | 06:07 PM
moedigga's Avatar
That would be no problem at all except my sweet $500 kodak digital is not working right now and of course I didnt get service plan with best buy so they wont touch it. Ill try though. Brabus told me that it is easy and most dealers know about it and automatically install. It is just a bolt and nut that go throught base of a-arm i think.-MOE
Old Aug 11, 2003 | 06:14 PM
  #32
moedigga's Avatar
The Brabus spring actually has a larger drop than say the H&R. Brabus recommends the #4 or #5 thickest pads for this reason. They also state that the spring is stiffer than the H&R which supposedly protects against sag in the long term. Which H&R supposedly suffer from. But we will soon see-MOE
Old May 17, 2004 | 02:17 PM
  #33
jbiZzyC43's Avatar
1998 C43 AMG
pad issue
I'm having an issue with the spring pads. I want to go the highest o my rear and want to change the front ones too. i called the dealer and they told me they only offer different sizes for the rear and none for the front. can anyone help please. will the rear ones fit the front also?
Old May 17, 2004 | 04:10 PM
  #34
KWiK's Avatar
Re: pad issue
No, the front and rear pads are not the same size. Try a search on this site for them, I know I have seen the part numbers posted in the past...
