C43 Euro Springs
C43 Euro Springs
Sup to everyone, I just wanted to do a euro drop without any major Aftermarket changes. The springs are $75 fronts for both and $71 rear for both, but I am planning to do the shocks all around, maybe OEM, or Bilstein andd if so, which Bilsteins? and bushings. what do you think is the best pads? I got #1 from the dealer with the springs and the 4 shock kit 210-990-03-99. Has anyone done so and how is the feel / ride / look?
![](http://i1127.photobucket.com/albums/l635/Tony_AMG/IMAG0219_zps044ac1e9.jpg)
![](http://i1127.photobucket.com/albums/l635/Tony_AMG/IMAG0218_zps7654ce7e.jpg)
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
You can read my thread in my signature below with all the C43 Euro specs
1995 C36 AMG, 1998 C43 AMG
Don't know, ask MB. They o.obviously raided their parts bin. If they are so cheap, get out and buy them!
My best guess would be if by any, the higher ground clearance in the US spec. I don't think they are cheap, they just did that for a higher stance back in 98-00. These "Euro" specs are actually pretty stiff, so maybe they have possible harsher roads in Europe per se. Either way, it's for looks anyway. The only downside of this would be that you would rip the bumper when you go over the parking stoppers as you pull away.
I found from a old thread a VIN for a MY2000 C43 AMG Euro:
FIN:WDB2020331F895478
This is what I get for euro stuff:
Front Shocks: 202-323-41-00 AMG Same as U.S.
Front Springs: 210-321-22-04
Rear Shock: 202-326-30-00 AMG Same as U.S.
Rear Spring: 210-324-34-04
As far as I'm concerned, everything on a C43 aside from Spring and shocks is the same US/Euro in general.
c43 has bilstein shocks from the factory. I would price them out from the dealer vs bilstein from a retailer.
that's not abnormal at all. many of the cars share parts. in a 202 there are many different part numbers, 140's, 210, 170, etc. totally normal. 202, 208, 170, 210 all have basically the same front end.
202-321-00-36 Lower spring spacer $6.25
210-321-01-95 Upper mount $5.50
210-330-87-07 LT Upper arm $224.00
210-330-88-07 RT Upper arm $224.00
202-323-41-00 LT Shock C43 $374.00
202-323-41-00 RT Shock C43 $374.00
202-326-30-00 LT Shock C43 $364.00
202-326-30-00 RT Shock C43 $364.00
203-324-00-84 Spring Shim $6.00
202-325-00-41 Lower spring brace $36.00
129-323-01-85 Torsion bar bushing center $12.50
124-323-49-85 Torsion bar bushing side $12.50
202-321-22-04 LT Spring C43 “Euro” $75.00
202-321-22-04 RT Spring C43 “Euro” $75.00
202-324-34-04 LT Spring C43 “Euro” $75.00
202-324-34-04 RT Spring C43 “Euro” $75.00
210-321-01-84 Shim $10.00
210-325-01-84 Shim $6.00
210-990-03-99 Shock kit $24.50
124-463-04-32 Steering shock absorber $71.00
202-460-05-05 Drag link $326.00
211-330-03-35 LT Ball joint $41.00
211-330-03-35 RT Ball joint $41.00
Everything, except for the springs/shocks, engine/entire emissions system including OBD, trim, and corner lights
And yes I'm aware of that, but seems odd that a seemingly quite specific AMG part would be taken from the bin. The springs and shocks are definitely different on AMG cars, and the AMG shocks have quite a premium on them, so I was surprised the springs were so cheap. Though if they're just normal 210 springs maybe that explains why. I wonder if the US spec, 202 numbered C43 springs are more expensive/AMG branded.
I was actually looking at the EPC and I noticed the numbers from DRB that were given were the "Esprit" edition. Not sure if the 43 came with a esprit package, so I could be wrong, but with that vin, for sure I am getting the US shocks / 210 springs / pads
True, Europe got the best out of C43...
Wow, I didn't know and looks like MB no expenses saved for once. I can't say the same for the Euro carbon trim...
