Secondary Air Injection Relay Location?
Old Jul 31, 2013 | 07:02 PM
RPB's Avatar
RPB
What is the location of the Secondary Air Injection relay on a '95 C36?
I have blown 2 air pump fuses recently and think this relay might be the culprit.
Thanks!
Old Jul 31, 2013 | 08:43 PM
cm60k's Avatar
I think the Air Injection Relay, comes in Pink color #: "001 542 74 19",,
located in the fuse box,, is your C36 comes with a same fuse box in the picture....??
ZAYED,,
Old Aug 1, 2013 | 06:46 AM
RPB's Avatar
RPB
Attachment 264294
ZAYED,,
Yes is does and thanks Zayed. I believe that part# is for the auxiliary cooling fan relay, no? I am a little stumped by this this one.
Old Aug 1, 2013 | 12:09 PM
cm60k's Avatar
You Welcome,,
According to the EPC, "001 542 74 19" is for an Air Injection Relay,, this Relay also can be a multi Purpose Relay,,
http://www.carpartsdiscount.com/auto...tml?3593=51748
do you check that in your fuse box....??
ZAYED,,
Old Aug 1, 2013 | 06:19 PM
RPB's Avatar
RPB
You Welcome,,
ZAYED,,
You were right Zayed, thanks again! I do not think the relay is damaged though because it also operates the aux fan and that is functioning fine. I just keep blowing the 40amp fuse for my sec air pump and got P0411 code, it must be something else going on. Any ideas please chime in, thanks.
