C43 Transmission Replacement
Old Jan 12, 2017 | 07:30 PM
  #51
cm60k's Avatar
Sorry for delay bro.,
if you want to go with 722.64xx, you will have to enlarge the hole of the gearbox mount bolts by 2mm, to let the mount set properly to the bracket,
and need to switch the gearbox flange, cause 722.631 using 3 fingers, while all 722.64xx got 4 fingers,,
you will have to cancel the shift release cable, that attaches to the end of the gearbox..
;ZAYED;
