C43 HEATER PROBLEMS
where are you located?
might be your duo valves being bad?
they are on the passengers side near shocknut, looks like 2 nipples attached next to each other if i'm not mistakin'?
if you or your buddies have a code reader get it hooked to your car or go to the stealership and investigate.
good luck finding the issue with your car
go back everytime you notice problems with your car and they should resolve them.
check your front seats air pressure bloating, if they don't work correctly could be $$$
tranny is $$$ when it fukks up
belt tensioner and harmonic balancer could ruin your engine if parts haven't been inspected
otherwise it's a good car if maintained well
