ESP keeps cutting power
Old Dec 27, 2013 | 10:56 AM
last2fall's Avatar
1999 c43 amg
So I had this strange thing start happening a few days back. When I am driving and make slight left turns around a long bend or something, the traction light starts flashing and cuts the power, i have to lift off and re-apply power, if it's a long sweeping turn when i lift off and accelerate again, same thing, its only until i straighten the wheel before it stops. If i turn ESP off, the light doesn't even blink at all around left turns. Is there a sensor that detects wheel spin somewhere? Any help is appreciated, and I should add, I am definitely not losing traction.
Old Dec 27, 2013 | 04:27 PM
popey24's Avatar
C43 AMG 5.5 - 396.4HP
Could be a wheel sensor or difference in wheel diameter. Check error memory.
Old Dec 27, 2013 | 07:06 PM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
+1 are you on OEM wheels/tires?
Old Dec 27, 2013 | 10:22 PM
cm60k's Avatar
Prefer to diagnose the car first, could have Errors in:-
1) Speed sensors
2) Angle sensor
3) Acce. sensor
4) Turn rate sensor
ZAYED,,
Old Dec 27, 2013 | 11:41 PM
last2fall's Avatar
1999 c43 amg
Yes, stock wheels, stock tire size. I noticed my front driver side tire was a little low so i filled them all to 32 psi, it seems to have been doing it less, but still there nonetheless. May just be in my head. Where are all these sensors located? I've been under there and just don't see where they would be.
Old Dec 29, 2013 | 09:05 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Have you had a wheel alignment recently?
Is the steering wheel straight when driving in straight line or is it off-centre?
Sounds like the steering angle sensor isn't in the straight ahead position causing it to think it's understeering on sweeping left hand bends and ESP is intervening. Most commonly caused by a steering wheel not being refitted in the straight ahead position relative to the steering column or a poor wheel alignment.
The lateral and turn rate sensor may be faulty, but it's very unusual that they would only be slightly out of spec to the point of giving symptoms but not enough to trigger the warning light.
I've also seen 1 car with worn rear control arms (thrust arms) do the same thing, but it was noticeable that something was wrong in a straight line too.
