Spring Pads
Old Feb 11, 2014 | 03:40 PM
mkoons's Avatar
1999 C43
Spring Pads
Finally gona do my suspension upgrade on my US C43. Doing Bilstein sports, Vogtlands, Kmacs in front, adjustable camber arm in rear and some other items.
Running stock 17in wheels. Question is what spring pads. Searched lot of threads and there does not seem to be a consensus on the pad sizes. I don't want rubbing but still want to get rid of that SUV look. Would appreciate some suggestions and why you like your choice.
Old Feb 11, 2014 | 05:24 PM
KJI3jflarryfe93's Avatar
i have the #1 front #4 rear pad combo
gives the car a nice look without rubbing issues
it's just barely the pinky finger will fit in the gaps.
gives the car a raked look
i think #1 and #3 combo is even better?
Old Feb 11, 2014 | 06:47 PM
mkoons's Avatar
1999 C43
Spring Pads
Thanks Kowalski,
We can always depend upon you for an answer. Are you using Kmacs or some other camber adjusters?
Old Feb 11, 2014 | 07:25 PM
fredtga's Avatar
w202
this was my c43 with hd bilsteins, h&r blue, #1 pads all around, kmacs in the front;
stock 17s, no rubbing in the back, slight rubbing against the inner fender on the front at full lock
Old Feb 12, 2014 | 01:57 AM
Originally Posted by mkoons
Thanks Kowalski,
i only have adjustable camber arms in the rear, nothing else
set up is
koni adjustable shox
vogtland springs
rear axle camber arms
complete new and rear axle suspension components
car now rides like a gocart
she feels more planted on tarmac
a lot more fun to ride her than before.
this was a necessary nip n tuck suspension modification
you get new car feelings on twisty roads and all other different road situations
Old Feb 12, 2014 | 11:33 AM
PJmak's Avatar
I think you should be fine with any number pads. From what ive seen, vogtland springs sit a bit higher then h&r.
Isnt there a thread with suspension setups from all members here and pics? If no then one would definetly come in handy so people can have some idea of what the car might look like/behave lime on certain suspension setups
