::ECS Tuning:: 722.6xx Automatic Transmission Wiring Harness Spacer Kit
Old Feb 19, 2014 | 04:58 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Kits Starting At - $17.31*
It's no secret that the wiring harness spacer on the Mercedes 722.6xx Automatic Transmission is prone to leaks. Over time, transmission fluid will begin to find its way past the seals on the wiring harness spacer and eventually wick up the wiring harness and get into the transmission control module.
Before this failed part causes more damage than a few spots on the garage floor, replace it using ECS Tuning's Automatic Transmission Wiring Harness Spacer Kit.
This kit includes the following items:
One (1) Automatic Transmissin Wiring Harness Spacer
One (1) Quart Of Automatic Transmission Fluid (Meets MB Spec 236.14)
One (1) Transmission Dipstick Tube Filler Cap Lock Pin
*Price subject to change.
Old Feb 19, 2014 | 06:33 PM
KJI3jflarryfe93's Avatar
these are all genuine MB parts you are selling?
what is the improvement on this kit?
pilot bushing was updated a few times from MB from poor design.
i have once replaced this pilot bushing on my C43 transmission because it leaked on the garage floor
Old Feb 20, 2014 | 02:38 PM
ECSTuning's Avatar
2012 SLS AMG
kowalski,
Yes, these are all OE parts in the Genuine kit, and aftermarket parts in the aftermarket kit. However, all parts, no matter if they are from the genuine kit or the aftermarket kit, are designed to meet MB specifications, including the transmission fluid (which meets MB Spec 236.14).
We have not made any improvements or design changes to anything in these kits, they are simply an easy way to buy all of the items you need to replace your Automatic Transmission Wiring Harness Spacer in one simple kit.
All of the parts in these kits are available as individual items if you do not want to buy the entire kit.
The Genuine Mercedes-Benz Spacer is available HERE, the Dipstick Tube Lock Pin is available HERE and the fluid is available HERE.
The Aftermarket Spacer is available HERE, the Dipstick Tube Lock Pin is available HERE and the fluid is available HERE.
If you have any more questions, please don't hesitate to post or send a PM!
