Secondary Air Injector Pump Relay P0410
Thanks in advance.
I was told that MB used to always replace the relays along with the pump, so I did. I'm almost positive now that a bad replay can cause these codes. Best of luck, it's not too expensive around $20-30 and is a good place to start! Sorry I am not sure which relay it is on your model though, but I am pretty sure that is the correct part # you have. It's definitely a multi purpose relay on my car.
