Help adjusting C36 (4spd) transmission needed
I need your help guys, the following is the situation.
My old transmission was messed up, the shifts had a delay in between like a slip.
So I bought a secondhand transmission for a c36 (4spd) with 55kmiles on it.
Installed it last week (I am not a mechanic or anything) so my nephew helped me with it.
It shifts smooth and without delays after install. Unfortunately it isn’t perfect. At WOT she shifts at about 5700 and doesn’t get to redline, this happens in all gears. However when I shift manually it stays in gear till redline as it is supposed to do at WOT.
To me it sounds that the gearbox needs some adjusting of some sort, what would you guys advice me?
Thanks for taking the time reading this,
if you find a specialist who knows MB go to him and ask questions about your issues.
good luck fixing your problem
