Leak from fuel pump/filter area
If you look at the bottom of your C43 (maybe C36 also) facing the rear on the passenger side, do you see any signs of leaks from the fuel pump/filter area? I didn't notice this until I looked under the car, but I saw signs of leakage from the gasoline supply system (pump, filter, tank), but I'm not sure where it's coming from. You'll not be able to see drips on the floor because of the pan cover. The leak seems severe enough that it ran over toward the exhaust pipe.
Do you guys also see fluid leaks on the rear transaxle?
first try to see where it is leaking, then tighten all clamps and fittings, also check the hose for any cracks.
Small seepage is normal with our old cars as the rubber and gaskets dry with age... You just need to check and be careful if you smell gasoline. You don't want your pride going up in a big fire
