99 C43 AMG, Bogging won't pass 20MPH
Old Oct 14, 2014 | 02:39 PM
hughc43AMG's Avatar
c43 AMG
Can anyone take pictures of the MAF inside the C43 Vehicle?, or am I going to have to go rouge and do it myself lol., and I order the part from ebay for only 150$ hopefully it will work.
Old Oct 14, 2014 | 03:21 PM
hughc43AMG's Avatar
c43 AMG
Exclamation
Best picture i can get of the MAF position
http://pingelblog.blogspot.com/2008/...on-sensor.html
Old Oct 14, 2014 | 03:36 PM
cm60k's Avatar
This may help;
http://www.pelicanparts.com/techarti...eplacement.htm
ZAYED,,
Old Oct 14, 2014 | 06:24 PM
DRBC43AMG's Avatar
Good find :-)
Old Oct 14, 2014 | 07:28 PM
hughc43AMG's Avatar
c43 AMG
cm60k thanks good find.
Old Oct 17, 2014 | 08:08 PM
hughc43AMG's Avatar
c43 AMG
MAF part came in today, to Rainy to install it, ill let you guys know asap if thats the problem.
Old Oct 19, 2014 | 08:49 PM
  #32
hughc43AMG's Avatar
c43 AMG
Ok, so intsalled New MAF, no more idle issue, and it seems to be going faster now, but it doesnt seem like a 300 TQ Car, my air filter needs to be replace i just took it out and basically recleaned it, my car does not burn out in first gear when i smash the gas pedal down like other c43amg, what you guys think? tune up or what.
Old Oct 20, 2014 | 04:48 AM
  #33
DRBC43AMG's Avatar
Good to know that the engine idles as it should and pulls strong again. Regarding for a need or not of a tune, do you have an idea when the plugs where changed? It is possible to change them yourself (x16) but access is a bit difficult and you need a good set of tools and different sized extension bars, etc. Access to the rear plugs is a PITA as space is very limited. However, if you have valve covers are not oil tight and need gasket changes, getting to the plugs is so much easier with the covers off. For the filters (x2) a quick clean is not sufficient except to remove dead insects and other muck. Paper filters need to be changed and are not expensive. An improvement in overall performance can be obtained by changing the fuel filter. This part is often totally forgotten as it lives under the right rear part of the chassis and you need to get to it from underneath. Prepare to find plenty of rusty screws and parts. Probably a new fuel pump and filter support will be needed.
Did you do a error scan with a OBD reader? That can also point out faulty areas which need to be looked at.
Old Oct 20, 2014 | 08:28 PM
  #34
hughc43AMG's Avatar
c43 AMG
Yup next step will be using OBD SCANNER will let you guys know asap.
Old Oct 21, 2014 | 01:10 PM
  #35
cm60k's Avatar
Originally Posted by DRBC43AMG
OK peeps, I removed the MAF sensor using this tool which worked fine for me (see below).
ID numbers on both sides of the sensor, so I made photos of both.
Hope it helps
Excellent Daniel,
i'm always suffering when i want to remove those damn screws, what screws you using instead of those..?
i'm using screws from diesel MAF's..
ZAYED,,
Old Oct 21, 2014 | 03:22 PM
  #36
DRBC43AMG's Avatar
I changed all the MAF. The sensor came from the old one.
Old Oct 23, 2014 | 08:59 PM
  #37
hughc43AMG's Avatar
c43 AMG
Just bought 2 new aftermarket air filters, but I wanted to know
which 5.4 engine plugs and play withs 99 c43 AMG, which year engine of e55 or other 55 fits in.
Old Oct 27, 2014 | 06:22 PM
  #38
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
You can read all about it here:
https://mbworld.org/forums/c36-amg-c...ap-thread.html
Some engines drop right in, some need an oil pump and pan change.
Also, I know you got yours figured out, but just for future reference for anyone who searches this thread, you can also get the MAS or MAF insert here:
http://www.germanstar.biz/MAF.htm
Old Oct 27, 2014 | 08:31 PM
  #39
hughc43AMG's Avatar
c43 AMG
i just Ebay mines works fine, $150 too BOSCH part MAF
Old Nov 2, 2014 | 12:00 PM
  #40
jgro1976's Avatar
99 C43 AMG
I had a similar issue with my C43. Bought the car, ran great. Did some work with the car off the street for a few weeks, afterwards it just had a dead spot while driving. Bought a genuine Bosch MAF off of Amazon for $100, fixed it.
As others have mentioned, also check your plugs, wires, coils, fuel filter, and oxygen sensors. All should be replaced around 100k.
Old Nov 2, 2014 | 03:29 PM
  #41
PJmak's Avatar
My wifes lexus is300 had same symptoms. I would press the gas but most of the time i had to lay off and do it very slowly for it to pick up. Cleaned the sensor and the car runs like a rocket
Old Nov 2, 2014 | 04:34 PM
  #42
mickey13's Avatar
1999 AMG C43
Lol. You have to run codes before anything. Would not have run out and bought a 150$ part without using a $10 code reader. Lol. What's up with three bad advice in this thread! Lololol
Old Nov 3, 2014 | 08:42 PM
  #43
hughc43AMG's Avatar
c43 AMG
Got no Code Checkers, But i just reorders 1 Air Filter already have 1 so just need another one to see if the full potential Horsepower of these car will be release once i install them this Thursday, because after i installed the MAF, my bogged went away and it was sort of beasting but it just didnt seemed like a 300TQ car.
Old Nov 3, 2014 | 10:10 PM
  #44
PJmak's Avatar
Resetting the transmission does wonders. Just make sure you manually take it through the gears for a couple dozen shifts. Rev it as high as you can
Old Nov 4, 2014 | 01:15 PM
  #45
ECTurboGSX's Avatar
Where are you located? Most auto parts stores at this point can read your code. You can get a cheap code reader for $40 (perhaps even less). You're spending more money throwing parts at it than if you spent the money on the code reader and got all of the information to make the right call the first time.
Old Nov 6, 2014 | 03:05 PM
  #46
hughc43AMG's Avatar
c43 AMG
how do you reset the tranny.....and ECU
Old Nov 6, 2014 | 03:59 PM
  #47
PJmak's Avatar
Disconnect the battery for 15 minutes(make sure you dont close the trunk)
Once its hooked back up, drive the car hard. Shift it manualy if you have to and hold the gear as high as possible but dont go redline on it. I would also take it out on the freeway for a bit.
The tranny needs to pick up on aggresive shifting now that its reset and it takes a certain amount of gear shifts i guess. I hate the damn adaptive transmission
Old Nov 21, 2014 | 05:57 PM
  #48
hughc43AMG's Avatar
c43 AMG
ok so havent disconnected the battery to restart ECU, but i got new MAF and 2 new air filters in, and its running pretty beast, maybe better if i restart ECU but its been awfully raining so maybe soon and keep you guys updated, thanks for all the help.
