Headliner Repair
Old Oct 28, 2014 | 10:56 PM
Tony_AMG's Avatar
1999 C43 AMG
Headliner Repair
So i decided to fix my headliner since it started to sag. I already took it out so im just going to post pics. I already disassebled the interior and have to reinstall everything back.!
RT Passenger side front upper
RT A pillar
Sunroof motor
Rear view mirror panel
LT A pillar
LT & RT Rear scuff removed
Backrest seat & center seats removed, plus the seat belt
B pillar trim removed (must unbolt the belt from front seat for trim removal)
LT Rear upper
B pillar
Scuff plate, body weatherstrip removed on both sides
Center back seat mounting location bolts (I removed and placed them back so they dont get lost)
Plastic trim removed for access removing the headliner removing the back seat
RT Rear c pillar (Back glass)
Old Oct 28, 2014 | 11:48 PM
cm60k's Avatar
That's so great Tony, definitely helps a looooooooooot,,
Thankss for sharing..
ZAYED,,
Old Oct 29, 2014 | 12:03 AM
Tony_AMG's Avatar
1999 C43 AMG
No problem, NOw all i have to do is removed the sunroof trim (have to remove sunroof glass as an assembly) I will take pics and try to give a step by step on it.
Old Oct 29, 2014 | 12:13 AM
cm60k's Avatar
i assure many fellows wait for it..
ZAYED,,
Old Oct 29, 2014 | 11:05 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
I've removed sunroof stuff, it's really simple:
Open sunroof half way, pop off the plastic bottom clip on the front edge bottom.
Close sunroof and put in popped-up position
Remove the bolts at 4 front (8mm I think) and idential 4 bolts on the sides holding it up.
Return it to closed position. From inside car, push up on glass and it will pop right out. Sunroof cover goes up and out the same way.
Old Oct 29, 2014 | 03:42 PM
Somalia757's Avatar
1995 AMG C36
This is awesome man, I have to do mine soon. Starting to sag now.
Old Oct 30, 2014 | 12:20 AM
Tony_AMG's Avatar
1999 C43 AMG
More updates. I already finished installing the headliner. I going to say this:
Re-install headliner RT front seat door, remove the check strap bolt from A pillar. open as far it can go. The reason this is is when pushing in the headliner with out the steering wheel in the way is much easier. And 2nd when doing so, make sure your right front seat is push toward the rear and set the back portion back all the way. 3rd you will need to put the Shift level in neutral or as further back as you can to get the headliner inwards. 4th YOU will have to kind of bend the headliner ever so slightly to you can get it through. I did it on my own with out any help and believe me it work and saves alot of time.
From here and on after you have installed the headliner and it is inside the car (not clip in inner panel) then should basic re-assembly from the way you took it apart. Here are more pics!!!
I did remove the nuts in gold instead of the torx screws. I suggest to water mark the guide so you can guide your self
I removed the 8 hex nuts and pulled back the glass. There is a plastic underpeice that has 8 double tabs so they have a way of getting it out from under the glass towards the rear.
No glass
Glass removed. Be careful to turn the seal to pop it our on both sides. On mine it ripped so I ended doing a repair on the seal.
My reinstalling guide
Opposite side
You should be able to pop out the glass liner panel.
Panel removed
There are guides on both sides. Be sure to check when removed. They come of the guide rail but are easy to reinstall. I Spent 45 mins trying to figuere this out LOL
Mounting glass support bracket with the guide rail on, this does not require any adjustments to the glass.
Same
Headliner installed after guide in the headliner brackets.
Make sure to press hard on some parts to get the headliner to fit correctly.
Old Oct 30, 2014 | 12:22 AM
Tony_AMG's Avatar
1999 C43 AMG
Heres the almost finished work!!!!!!!!!
Old Oct 30, 2014 | 05:56 AM
DRBC43AMG's Avatar
Great thread and instructive for those with the sagging liner problem. Just wondering if removal of all the seats would have made things easier for access.
Old Oct 30, 2014 | 09:54 AM
Sulaco's Avatar
I want to go all black too, but the mismatched sun visors and handles would drive me crazy!
Old Oct 30, 2014 | 01:32 PM
DRBC43AMG's Avatar
If you can find a way of getting this in the DIY stickies that would be great. Send a message to an administrator. That should work.
Old Nov 2, 2014 | 10:58 PM
Tony_AMG's Avatar
1999 C43 AMG
Dude honestly the car stands out interior wise if its black headliner. since my car is 2 tone, black and grey, its like a win win. If & when I decide to reinstall the moon roof interior panel. I gonna leave it grey, but I took it off for the moment anyway.
