Washer Tank Question
Old Nov 2, 2014 | 12:19 PM
mkoons's Avatar
1999 C43
My windshield washer tank is leaking, need to remove tank to find leak. If I remove tank and drive car I assume radiator fluid will be pumped out of the 2 lines that feed in and out of the tank to heat the washer fluid.
Would appreciate if someone can comment on this.
Old Nov 2, 2014 | 12:53 PM
eFifty5AMG's Avatar
2004 E55
Originally Posted by mkoons
My windshield washer tank is leaking, need to remove tank to find leak. If I remove tank and drive car I assume radiator fluid will be pumped out of the 2 lines that feed in and out of the tank to heat the washer fluid. Would appreciate if someone can comment on this.
Just buy a new one IMHO. I tried, by first replacing the rubber grommet washers by the pumps, but didn't fully remedy the leak. I wasted a few gallons of windshield fluid throughout my trials. Ended up replacing the entire unit. Quite an task to complete.
Old Nov 2, 2014 | 05:05 PM
mickey13's Avatar
1999 AMG C43
Yeah just but a new one but don't forget your checkbook. I bought 1 screw from the stealership and it was $10. LOL
I should have just matched it at the hardware store but hey I want my car to have genuine Mercedes parts! ;-)
Old Nov 4, 2014 | 04:06 PM
mkoons's Avatar
1999 C43
After driving car I can feel all around under tank by pump and can find no indication of fluid leaking. I dont think tank is cracked, must be a connection somewhere that is leaking.
Old Nov 8, 2014 | 02:17 AM
JohnnyRock's Avatar
1998 C43 AMG
Autohausaz.com has new washer reservoirs at $67. Grommets are .79c/ea.
