X pipe vs hollow cat
Old Jan 28, 2015 | 08:49 PM
akimoto168's Avatar
98 C43
Hey guys, I have started to develop a rattle on my secondaries, and now have the option of doing an X pipe or hollowing my secondary cats.
Being a CA resident, I like the look of having the cats there, and having them hollow. However, I heard an x pipe sounds better. I've heard sound clips of resonator delete + secondary delete (assume it is using a welded 2.5" pipe), but I've never heard any clips of a cat hollowed and welded back.
Would like input on which option I should choose
1. Cat hollowed out and welded back
2. X-pipe installed
*resonator already deleted
Thanks1
Old Jan 28, 2015 | 09:24 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I don't think you'll notice much gain in performance/sound with an x-pipe.
Because the exhaust already merges into one pipe after the resonator.
Good luck,
Faiz
Old Jan 28, 2015 | 09:30 PM
eFifty5AMG's Avatar
2004 E55
If your resonator is already removed, how did you merge the two? Our exhaust would need a y-pipe to merge both into one, not an x like the 210 E55 which is a dual to the muffler. I say, hollow out the secondaries in addition to the deleted resonator.
Which leads me to this next question; will the 210 E55 exhaust work on a C43? From the primaries back, would it flow better? The exhaust notes on mine sound similar, but for some reason, I'm more partial to the E's.
C43: Y-pipe
E55: X-pipe
Old Jan 29, 2015 | 12:00 AM
PJmak's Avatar
The engine size also contributes to the sound. After a 5.4 swap although its hard to tell, i have to admit that my car is a little more quiet
Old Jan 29, 2015 | 08:27 PM
akimoto168's Avatar
98 C43
Has anyone heard clips of a c43 with punched-out cats?
Old Jan 29, 2015 | 08:30 PM
Solo wing's Avatar
I don't think it'll be much different than cat delete, because it's like a straight pipe.
You'll find plenty of videos on YouTube for - resonator+2nd cat delete.
Faiz
