Central lock pump issue
Old Feb 15, 2015 | 09:42 PM
88260EEE's Avatar
1998 C43, 05 Mini Cooper s
The past few days I notice that that as I drive every ten minutes or so I here the central locking pump pumping in the trunk area???? Does it while parked as well, luckily does do it with the car off??? 1998 c43
Old Feb 15, 2015 | 09:56 PM
cm60k's Avatar
Did you check all vacuum connections in the pump..?, is safety lock after 20/25 miles working..??
ZAYED,,
Old Feb 16, 2015 | 08:21 AM
88260EEE's Avatar
Haven't checked anything yet, all I been doing here in Boston is clearing snow!!! Doors do auto lock, thinking it might have to do with the trunk lock! It was seized for a long time!
Old Feb 16, 2015 | 09:11 AM
cm60k's Avatar
These PSE pumps fails by vacuum hoses leak/crack in white plastic connector inside/random fail of vacuum motor:-
http://www.benzworld.org/forums/w210...ode-b1439.html
ZAYED,,
