Camber Bolts - A 202 330 01 18
Old Feb 25, 2015 | 03:04 PM
pedrobenz's Avatar
1991 190e 2.3
I have 4 of these - A 202 330 01 18 (camber bolts) and I could not remembered why I ordered 4. I recently lowered my C43 with Eibach Prokit and I am wondering if I need all 4 camber bolts installed. I could only see 2 in the front. Do you have any images where I should install these camber bolts? Thanks much.
Old Feb 25, 2015 | 10:59 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
DO POINT OUT THAT THESE BOLTS (2 CAMBER AND 2 CASTER) ARE ONLY AVAILABLE FOR FRONT AND ARE ONE POSITION – NOT PRECISELY ADJUSTABLE!
Only allowing minimal .3 of one degree (1/8 of an inch – 3mm). To change means labour intensive disassembly each time.
While K-MAC front kit – replaces not just the bolts but each entire bush (which are the 4 front highest wearing bushes).
Along with the unique K-MAC patented design allowing precise single wrench adjustment accurately under load direct on alignment rack (with 3 times the adjustment range on W202 models).
Allowing precise (ongoing) adjustments to correctly resolve premature tire wear, steering pull – also essential if altering height, fitting wide tires/wheels, load carrying or curb knock damage.
Similar rear Camber kit (OEM – only Toe adjustment) which also includes extra Toe adjustment to compensate for the rear camber facility. Bush extraction/insertion tools supplied with both front and rear kits.
Old Feb 25, 2015 | 11:38 PM
pedrobenz's Avatar
1991 190e 2.3
How much is your camber kit?
Old Feb 26, 2015 | 12:52 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
$480 for front camber and caster adjustment according to their site.
Old Feb 26, 2015 | 04:32 PM
Pagz's Avatar
C43 w/clk55 Organs
I've measured the camber correction with these bolts(all 4 installed) ,they are only good to Hub-fender ~331mm which gives 1.20'' degrees front camber. anything lower you are going to want more adjustment.
