C43 with 55 swap quest for 12's
Old Apr 12, 2016 | 12:09 PM
Agrovain's Avatar
C55
I recently purchased a C43 for the sole purpose of swapping in a 55 engine. I used to own a W203 C55 but was forced to sell it for financial reasons. I didn't waste any time modding my C43 by swapping in the 5.4L from an '02 CL55, cutting out the resonator/secondary cats, and installing H&R super sport lowering springs. The previous owner installed an EBay axle-back 3"in exhaust and K&N drop in filters. The car runs 13.4 in the quarter mile with these mods. What are some more things I can do to help me get into the 12's?
Old Apr 12, 2016 | 01:33 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
13.4 is about as good as it gets for any N/A C43 with a 55 swap.
Your only real option is to add a supercharger. If we were talking going from 13.4 to 13.3 or 13.25 you could maybe work on the intake or exhaust, reduce the gross weight and unsprung weight. But shaving off a half second? We're talking a legit upgrade here.
Old Apr 12, 2016 | 02:43 PM
PJmak's Avatar
Whats up bro this is PJ from from Sacto.
You need a LSD. With good tires you can cut down to 13 flat
Old Apr 12, 2016 | 04:16 PM
Sulaco's Avatar
I stand corrected. Boy was I wrong
That guy hit 12's with full 3" exhaust and probably an LSD
Old Apr 12, 2016 | 05:44 PM
sick430's Avatar
CLK Cabrio
Originally Posted by Sulaco
I stand corrected. Boy was I wrong C43 / C55 drag run - YouTube
This was moneyone's car. he eventually swapped a 55K motor in there. I believe this run is just the 55 with bolt on and an LSD.
Old Apr 12, 2016 | 05:54 PM
sick430's Avatar
CLK Cabrio
With the 55K swap
Old Apr 12, 2016 | 11:03 PM
PJmak's Avatar
The run was with a NA 5.4
Do we really thing a 55k w202 would struggle to break into 12s?
Old Apr 13, 2016 | 09:18 AM
Sulaco's Avatar
I was way wrong. NA 5.4 can hit 12's apparently!
Old Apr 13, 2016 | 09:58 PM
Quant's Avatar
2002 CLK55
Like everyone else is saying 12s are achievable on c55 with proper exhaust + tune + lighter wheels and LSD type diff.
PS car looks great, it has a very subtle aggressive stance
Old Apr 14, 2016 | 03:27 AM
Sulaco's Avatar
Have we ever been able to conclude that a tune on a C55 helps at all?
Someone in the UK mentioned using injectors from the CL55k motor and seeing over 20hp more, though.
Old Apr 14, 2016 | 04:48 AM
cm60k's Avatar
I don't think 55K injectors will work, even with ECU tune, to much RICH mode..!!
(C43/C55 217cc/283cc) VS (32K/55K 396cc)
our ME2.0 ECU has a limit E-prom file to rise-up fuel mixture, that's why MB Expand their file after 11/2002, to (ME2.8>>ME2.8.1)..?!?
ZAYED,,
Old Apr 14, 2016 | 12:38 PM
Agrovain's Avatar
C55
I was able to cut down to 13.2 I'm sure it's because the sun went down and the air was much colder. I also weighed the car with all factory equipment and a 3/4 tank of gas. It weighed in at 3400lbs!
Old Apr 14, 2016 | 01:18 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
At 3400 with a c55 motor you should be able to get into the 12s with lighter wheels and better tires.
There is a definite improvement on the c55 with a tune. Is it a lot for the cost? No but what is on these cars. The cheapest easiest way to drop 10ths is to drop weight. Are you still running a spare tire? Back seats?
Old Apr 14, 2016 | 02:19 PM
PJmak's Avatar
What tires? I remember you saying you used crappy tires
Old Apr 14, 2016 | 03:07 PM
Sulaco's Avatar
Removing the front seats and using a light weight Recaro for the driver seat would shed a lot of pounds
Old Apr 15, 2016 | 04:33 AM
DRBC43AMG's Avatar
^+1 and removing passenger seat would also save some extra weight
Old Apr 21, 2016 | 03:33 PM
Agrovain's Avatar
C55
Old Apr 22, 2016 | 03:52 AM
DRBC43AMG's Avatar
Wondering how you can improve gear shifts on our transmissions. With quicker changes I guess this should improve things considerably.
Old Apr 26, 2016 | 04:44 PM
Sulaco's Avatar
Any idea what a 55 swapped 43 can do zero to 60?
Old Apr 26, 2016 | 11:26 PM
svt ricco's Avatar
1999 C43 AMG
5.5-5.7 according to Mercedes enthusiast magazine
Old Apr 27, 2016 | 12:20 AM
PJmak's Avatar
I cant tell you how frustrated I am when I see stuff like this above. I know you are just quoting someone ricco so its not you.
Someone who reviews cars should know about mercedes adaptive transmitions. Not being properly reset, the trans can cost you as much as a third of a second probably.
If a w210 e55 can do zero to sixty in under 5 seconds then its safe to say that a w202 will match that no problem and then some
Old Apr 27, 2016 | 01:58 AM
DRBC43AMG's Avatar
C43 has to be lighter too
Old Apr 27, 2016 | 08:00 AM
Sulaco's Avatar
I know the feeling, man. There's not much internet research you can do on our cars, even the stock 43's. I know we've been over how every magazine had wildly different figures for the stock motor's 0-60 time. I know I've never seen one take 6+ seconds to do it. I measured 5.6-5.7 in mine with the old 4.3 motor when it had 250k miles. Haven't done anything in my current one after the 55 swap because I'm STILL chasing a weird rear-steering issue that is only gotten worse with the added power.
But you're right, if the 210 E55 can do it in 4.9 weighing 300lbs more, there's got to be some kind of parity between the 2 cars. The C55 has worse exhaust but identical intake.
Old Apr 27, 2016 | 08:54 AM
mickey13's Avatar
1999 AMG C43
I thought the 55k swap was a no go, problem with the computer and all?
Old Apr 27, 2016 | 08:57 AM
cm60k's Avatar
I'd love to see someone can modify diff. to "3.46" or "3.69",,
start from dig, or drifting will be sooooooooooo EXCITIIIIIIIIING...
ZAYED,,
