vacuum pump/seats question
Old May 7, 2016 | 02:11 AM
PJmak's Avatar
My air seats in my car occasionaly dont work. Adjusting the air doesnt do anything but then all of a sudden it works. Also today I noticed the vacuum pump is continuously making sounds while driving. Its the kind of sound that you hear when you unlock your car using the unlock button inside the car. That quiet whine sound from the rear passanger side.The sound is repeating every few seconds and the only way to turn it off is to hit the unlock button inside the car while driving.
If you have any ideas what might be happening please do share
Old May 7, 2016 | 07:17 AM
KJI3jflarryfe93's Avatar
ZV pumpe in kofferraum vielleicht kaputt?
or maybe your vaccum hoses burst into leaking air?
pop your trunk, all 4 doors, go around your car and listen to air leaks when you lock your car with remote.
if your problem is with seats you might have to remove them as vaccum lines goes under carpets
jos jedna frka ti se pokazala s auto, sta je to bre?
problems creepin' up on ya
did you neglegt your car for many years it turned into a sour lemon?
my advice find another solid C43!
Old May 7, 2016 | 12:03 PM
PJmak's Avatar
Haha shes getting old mayne. Aproaching 190k
The seats were swapped a few monts ago. Everything looked normal and all the lines were fine.
Ill see if I can figure out if there are any leaks and ill report back
Old May 7, 2016 | 12:29 PM
brate, having some balkan humor is a must, makes life a lill easier!
maybe it's simple as a loose connection popped off or if your hose connectors going bad?
Old May 7, 2016 | 06:30 PM
mickey13's Avatar
1999 AMG C43
lol
Old May 7, 2016 | 09:32 PM
PJmak's Avatar
Vtrust me I get balkan humor in my life every day lol
Old May 8, 2016 | 07:00 AM
