Ground Points and list of modules
Does anyone have a diagram of all the ground points on the w202. It may be listed in the Haynes Manual or somewhere else.
I found this diagram for the W203, but I don't think it is the same as the W202.
E1 - bulb failure control unit (18)
E2 - LH tail light unit (45)
E3 - LH number plate light (42)
E4 - RH tail light unit (46)
E5 - Battery (1)
E6 - (buggered if I can find it!)
E7 - Fuel pump (103)
E8 - Passenger fusebox (85)
E9 - Fuel injection control unit (88) Also fuel pump relay (102)
E10 - Fuel injection control unit (again 88)
E11 - Fuel injection control unit (and yet again 88)
E12 - LH front door switch (82) and transmission switch stage illumination (81) LH rear door switch (73)
E13 - RH front door switch (79) RH rear door switch (74)
Also wondering of anyone had a complete list of all the modules the W202 uses. I am working on tracking down the short in passenger taillight that blows the fuse when I hit a bump. Is there a module that controls the passenger tail light?
E5 - Battery (1)
