Part # Confusion - Shift Lever Assembly
My EPC tells me the part number for the shift lever assembly is 202 267 08 24, replacing 202 267 04 24. However, my local MB dealer, Pelican Parts and Autohausaz all list the part # as 129 260 45 98. So the question is can I use any of these part numbers? Can I use any shift assembly out of a 1998 W202?
Thanks in advance.
These things rarely go bad and you can probably get a solid one for $50
Any W202 shifter should work 98-2000. All I know maybe even w208 or w210 ones are compatible
I would also change the rubber bushings on the link that goes from the handle to the transmission lever, underside.
Also some years back I think member 503C43 ////AMG on here did a great DIY for dismantling and rebuilding the shift unit. If I find it I'll add the link later...
