Vacuum or vent tube near battery?
also i guess the battery can explode if not vented so yeah make sure you vent it. not good to have things exploding right on top of your gas tank
Last edited by mickey13; Jul 20, 2017 at 08:41 PM. Reason: added info about venting
check if you have the vented hole in front next to the fuse box or the other side next to the tail light?
if the hole is vented on the wrong side of the battery you need a longer hose to plug into your battery.
watch out for acid leaks from battery, battery under tray will corrode looking like poop.
there are spezial battery carpets absorbing acid you can place under the battery.
I think DRBC43 had some nasty leak from a battery on his under tray many years ago.
Make sure the tube is connected at all times and when changing battery ensure it has the breather outlet.
