Only right side gets heat?
Old Dec 3, 2017 | 10:45 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Left side gets whatever temp air the cabin is. Duo valve or vacuum problem? Vents work normally in all other situations so I'm leaning duo valve?
Old Dec 3, 2017 | 08:25 PM
mppp's Avatar
1996 Mercedes-Benz C36 AMG
Did some searches and ran into the your conclusion as well on MB W202s. Other car types talk of a heater core flush with a garden hose worked for them.
Old Dec 4, 2017 | 04:02 AM
DRBC43AMG's Avatar
Probably sticking duo valve. Tap gently on both sides of the valve to see if that get's the sticking piston free. You can dismantle and clean the duo valve but be careful with the seals. Removing the valve is a little tricky but that makes things easy after.
