C43/55 Starting Problem
Old Dec 3, 2017 | 03:27 PM
C43Swap's Avatar
1999 Mercedes C43 AMG, 2002 Mercedes S600
Getting straight into it. I e55 swapped my c43 and in the process also changed the factory transmission with the e55's as well. There were some differences in the shift interlock for moving out of park. Now that everything's in the car though i cant get the car to turn over. I am getting power to the starter however the ecu is not sending power to the starter solenoid. I have all wires connected except the o2 sensors, all grounds are on as well. Is it possible that because the c43 transmission had a mechanical shift interlock and the e55 had an electronic interlock that it could cause the starter to not engage. I'm stuck and confused so any feedback's appreciated thanks!
Old Dec 4, 2017 | 04:07 AM
DRBC43AMG's Avatar
Could be as the ECU thinks the transmission is stuck in a gear. Are you trying to start in position P or N. No difference?
I guess someone having done this transmission swap should be able to point out potential problem area to check.
Old Dec 4, 2017 | 10:43 AM
C43Swap's Avatar
Yea I tried going through all the gears not just park and neutral with no luck. I also went around with a power probe and checked all my fuses and relays still no luck.
Old Dec 4, 2017 | 09:17 PM
ecmexchange's Avatar
Former Vendor of MBWorld
na
If you need to replace the ecu, which hopefully not, give us a call, I'm sure we have one that will work! 1-888-875-2958
Old Dec 5, 2017 | 02:16 AM
DRBC43AMG's Avatar
Don't know but could the problem be coming from the TCU? Should you install the one from the E55?
Old Dec 5, 2017 | 08:28 PM
C43Swap's Avatar
New update I got the car to start. I had a ground going to the ecu. Thanks for all the feedback.
