Rear Spring Removal + Replace
For those of you who have replaced springs on your C43, do I need to remove the lower control arm in order to remove the rear springs safely? (note the word, "safely"). I've watched numerous YoutTube videos on rear spring removal and this is one of the best I've seen. Although the video is for the W211 chassis, the suspension components are practically identical to ours.
However, the tech in the video does remove the rear mounting bolts for the swaybar link and shocks in order to drop the control arm far enough to remove the spring without the compressor. I have the Mercedes spring removal tool and the rear shocks are being replaced as well, so I thought I should tackle installing the Vogtland springs I bought about 6 years ago!
Advice and comments on the best way to tackle their removal is appreciated.
PS. SInce Photobucket blows, which image hosting sites work best for posting pics here?
Edited to add that if you have the OE N. America springs which make the 43 look like an "off road" vehicle, I would be extra careful as they are longer on overall length than the Euro ones, so could bite you if you're not careful
