'98 C43 - won't start - help?
I have a otherwise perfect '98 C43 with 67K miles, and all of the sudden it won't start. The battery is OK - starter motor definitely spinning the engine up when the key is turned.
It has been at a local MB mechanic for a week now, and he seems to be having a hard time figuring out the problem. He now thinks it might be the main central computer, but this is extremely expensive.
Does anyone have any suggestions or ideas of what it could be, or had a similar problem with a C43 and solved it?
Any help would be appreciated!!!
have you check to see if you hear the fuel pump turn on when you turn the iginition key? you should hear a buzz from outside the car on the passenger side rear. otherwise, you might not be getting spark to your plugs. without seeing the car it would be hard to diagnose and everything would be just speculations, but i would also check all fuses because for engine to run, you need spark and fuel.
but if you MB shop can't figure it out, then i dont kow how much of a help i would be. good luck
ps. see if you tech can hook up a star diag to your comp to see what the last error if any was. that might also give him a clue as to the cause.
