Put Ecu from E320 into C36
mercedes c220 c36
Since i Think im having problem with my ECU i want to try to put anoter one into that and sees if he runs.
Will a Ecu from a different m104 Engine works? since the ecu from c36 amg is pretty rare to find and i dont want to change it its not that isn't working. And its much easier to find one to a 280 or a 320
mercedes c220 c36
Transmission has nothing to do with the ecu on these cars. I ran a E320 ecu in my 3.6 swapped W124 for quite a while until I had the ecu chipped. No reason to think you could not do the same thing with the C280 ECU in the C36.
mercedes c220 c36
any tip?
'99 and '05 E55 AMG
STOP!
The ECU is mated to the car via the VIN. You *cannot* install another ECU unless you purchase it from the dealer (and have them initialize it) or purchase one that is "virginized" by an aftermarket ME (Motor Electronics) supplier and then initialize it yourself using DAS/STAR/XENTRY (whichever is right for your model year car). Perform an internet search on "Passenger Car Drive Authorization Systems", download, read, and you will understand.
00 C200 & 00 C55 & 06 SLK55
If you have EZS ignition switch system with infrared key, then can't put ECU only..!,
you will have to get complete Ignition system, "ECU/ESL/EIS/Key",,
also, not prefer to put (E280 2.8L) or (E320 3.2L) ECU, due to differ (C36 AMG 3.6L):-
"camshaft/heads/pistons & cooling nozzle/crank/Exh. valves & valve springs/timing angle"..!?!?
-;ZAYED;-
-;ZAYED;-
mercedes c220 c36
-;ZAYED;-
-;ZAYED;-
So thats why i Think i need to change it
