washer reservoir diagram and parts numbers
Old Oct 9, 2018 | 01:07 PM
mickey13's Avatar
1999 AMG C43
can someone share the washer reservoir diagram and parts number list. i have a leak and i think i already found it. just curious as to what the cost of a new parts are instead of duct tape repair LOL
Old Oct 9, 2018 | 02:49 PM
mickey13's Avatar
1999 AMG C43
Originally Posted by kowalski
you do know washer fluid is highly flammable?
be careful you don't get any squirts on your exhaust
Old Oct 10, 2018 | 04:01 AM
DRBC43AMG's Avatar
Here's the info in 2 .pdf files. I used the N. American EPC just in case there are differences between N. American and ROW versions
File Type: pdf
File Type: pdf
Old Jun 21, 2019 | 07:17 AM
mickey13's Avatar
1999 AMG C43
Heads up for anyone who might need to order the pane pump listed as part #66. The parts list has the wrong number, it has it listed as A 210 869 08 21. I know that is wrong because I ordered it. I was told the correct part no is 2028690021. Initially, I thought supplier had it mixed up but now I believe that EPC is incorrect because a search of other suppliers with the original part number supplied by EPC turns up the wrong pump as well. Pump is easy to distinguish as connectors are different. Closer inspection shows that diameters are not the same as well. Will update when new pump arrives.
Old Jun 21, 2019 | 07:53 AM
DRBC43AMG's Avatar
Let me check the references in the new EPC
Old Jun 21, 2019 | 12:28 PM
cm60k's Avatar
I replaced this washer tank pump last week,
"210 869 08 21" part # is correct, it's also optional with "210 869 09 21"--
-;ZAYED;-
Old Jun 21, 2019 | 01:16 PM
cm60k's Avatar
Also, you can go with "202 869 01 21" or "202 869 02 21" for "W202/W208/W210" headlight (washer/wiper).
-;ZAYED;-
Old Jun 21, 2019 | 01:21 PM
DRBC43AMG's Avatar
Oh dear, looks like several options are available. Just need to know which one is the right one. Could it be the washer bottle may be slightly different from one year to another and model of W202? If I recall my c240 wagon had the same type of bottle
Old Jun 21, 2019 | 01:44 PM
mickey13's Avatar
1999 AMG C43
hey zayed. yeah idk. just my experience. google search of A 210 869 08 21 pulls up the same type that i have in my pictures which does not fit in my car. i have the older 2 prong with plastic guide type plug
Old Jun 21, 2019 | 02:12 PM
cm60k's Avatar
That indeed depends to your washer system spec..!,
A) "210 869 08 21" or "210 869 09 21, for non-headlight wiper system.
B) "202 869 01 21" or "202 869 02 21", for Headlight wiper system.
-;ZAYED;-
Old Jun 21, 2019 | 02:19 PM
DRBC43AMG's Avatar
Thanks Zayed for the info which completes the thread
Excellent
Old Jun 21, 2019 | 02:38 PM
mickey13's Avatar
1999 AMG C43
mystery solved.
daniel, no wipers on your headlights?
Old Jun 21, 2019 | 06:36 PM
DRBC43AMG's Avatar
Yes indeed as I have Xenons, it's mandatory
Old Jun 22, 2019 | 12:44 PM
mickey13's Avatar
1999 AMG C43
So my heros over at FCPeuro overnighted the new part to me with a Saturday delivery. They didn't charge me extra for the special delivery, mighty nice of them. The part that came is 202 869 00 21. It doesn't look like it's going to fit though... base of the old part is bigger then new park
Maybe it will, who knows, going to give it a shot.
Old Jun 22, 2019 | 01:25 PM
mickey13's Avatar
1999 AMG C43
Welp it fit. Another solved dashboard light. I've had a nice run in the last few weeks since I started tinkering again. Check engine was solved with a fuse, light out was solved with a new bulb, washer was solved with a new pump. I have 4 lights left today. 1 is low gas, pretty easy to solve that one. 2 are related to the brakes and ABS, pretty sure new rotors will solve that, have to get to it this summer. and the last light that has eluded me for about two years is a light out only when headlights are on. One of my tail lights does not get current. I'll start with that one after the brakes.
few pics to share
correct part no
Snug as a Bug
New Cap, old one was cracked and yellowed
no more washer light
looks like working
no leaks?
Old Jun 26, 2019 | 05:14 PM
mickey13's Avatar
1999 AMG C43
so washer light was on again today. slowwwwww leak somewhere. will pull the unit and try to inspect closer. before replacing the motor it was a fastttt leak so i am guessing my rough hands fixed one problem and created another. we will soon see.
Old Jun 26, 2019 | 06:04 PM
DRBC43AMG's Avatar
Looks like you are overdue an oil change and service
Old Jun 27, 2019 | 05:56 AM
cm60k's Avatar
You have to replace the pump rubber seal,,
usually, it's worn out when you remove the old pump..
-;ZAYED;-
Old Jun 27, 2019 | 06:01 AM
mickey13's Avatar
1999 AMG C43
HAHA. Yeah, do you actually use that? I've been doing 5k oil changes.
mickey13's Avatar
1999 AMG C43
yeah, kicking myself for not ordering that too when i put in the new pump. LOL
-;ZAYED;-
Old Jun 27, 2019 | 06:10 AM
DRBC43AMG's Avatar
True a new rubber seal sounds the way to go. Don't forget the washer tank is heated, so I can imagine the seal does have a tendency to dry, become brittle , crack and leak over time
