LED lighting
Old Oct 30, 2018 | 01:28 PM
silverc4s's Avatar
99 C43, 73 911 targa
LED lighting
Because my C43 has a CANBus wiring system, I purchased a CANBus compatible replacement 1156 led lamp when my brake lamp burned out. It works great as a lamp (very bright) but I am still getting a lamp out indicator on the dash.
Has anyone else converted any of their lamps to led with success? I would like to eventually replace all incandescent lamps with leds, but it may mean a constant lamp out warning? Any advise?
i am going to ask Superbrightleds.com as well, I have had good service from them in the past.
BTW, I changed both rear brake lamps at the same time.
Old Oct 30, 2018 | 06:20 PM
DRBC43AMG's Avatar
There are led bulbs and led bulbs and some will give warnings and others not. I guess you need to choose carefully your bulb supplier. My daily workhorse Renault Twingo has second generation led bulbs everywhere except for the headlights and NO faults warnings. The older ones did give often faulty warnings.
Old Oct 31, 2018 | 08:03 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
LED's from Aznoptics in both my C43 and E63 with no issues at all.
Old Nov 1, 2018 | 09:48 AM
silverc4s's Avatar
thanks, 503, I guess I will order a pair from Aznoptics and try. They are a bit more, 30/pair, vs 18/ pair, but if they work it’s still a good plan...
the ones I have are a constant lamp fail warning.
Old Nov 2, 2018 | 12:18 PM
DRBC43AMG's Avatar
I guess you have your reply in differences between quality of LED lights
Old Nov 4, 2018 | 03:32 PM
silverc4s's Avatar
right you are. Really disappointing as the ones I bought were specifically for CANBus applications, and cost a bit more than standard too..👎
Old Mar 27, 2021 | 06:05 PM
zill's Avatar
2008 CLK 550 2012 C300
Hey John,
don’t bother. I tried out a few LED bulbs In my clk. The low amp draw of LED draw compared to the incandescent OE creates an error. The system doesn’t recognize such a low draw.
I got a few in my shop, glad to send you if you want. Other forum members may disagree or have workaround.
zill.
