C43/55 track car manual transmission conversion
Old Mar 30, 2019 | 04:21 PM
  #51
East Coast Euro's Avatar
Former Vendor of MBWorld
C63 and CLK55
Originally Posted by ECTurboGSX
No issues with the exhaust when lowering the engine by 10 mm? Also, aren't the mounts on a slight angle towards each other and shortening them would cause them to be farther apart cross-car?
10mm shorter than a brand new oem mount. OEM mounts get shorter with use. This actually allows more clearance of the headers to the chassis for many cars
And no they are designed to fit perfectly and accounted for the lower height in the design. They are installed all over the world
Old Jun 17, 2019 | 03:32 PM
  #52
raw1879's Avatar
Mercedes C55 AMG
Old Jun 17, 2019 | 04:23 PM
  #53
cm60k's Avatar
Hey Rob, you are the Champion..
-;ZAYED;-
Old Jun 17, 2019 | 04:31 PM
  #54
cm60k's Avatar
These mounts really looks sensational..,
how many kind of stiffness you have for both Engine & trans, mounts..?,,
i bought Yellow (90SHA) stiffness of "Swaybar bushings/upper & lower control arms/rear tie Rods/rear subframe bushings/
spindle bushings"..
-;ZAYED;-
Old Jun 17, 2019 | 05:13 PM
  #55
raw1879's Avatar
Mercedes C55 AMG
-;ZAYED;-
Thanks the cars in a great place now I’m just going to enjoy it now
Old Jun 17, 2019 | 05:17 PM
  #56
C63 and CLK55
spindle bushings"..
-;ZAYED;-
Thank you Zayed.
We have street and race poly stiffness for engine mounts and transmission mounts.
Old Jun 17, 2019 | 06:00 PM
  #57
DRBC43AMG's Avatar
Nice smooth driving Great to see a W202 shuffled around like that
By the way, is the EPS left switched on? Looks like it. The LSD does make for good road manners.
Good work
Old Jun 17, 2019 | 06:10 PM
  #58
cm60k's Avatar
Thank you Zayed.
Assuming you have (85 SHA) for street & (90 SHA) for race, isn't..!?
-;ZAYED;-
Old Jun 18, 2019 | 09:16 AM
  #59
mickey13's Avatar
1999 AMG C43
yes, definitely awesome build! thanks for sharing!
Old Jun 18, 2019 | 10:50 AM
  #60
PJmak's Avatar
Any improvement in lap times with the manual trans?
Old Jun 18, 2019 | 01:45 PM
  #61
C63 and CLK55
-;ZAYED;-
No. Because the poly is encased in billet housing we don't need to go that stiff.
Old Jun 18, 2019 | 02:40 PM
  #62
cm60k's Avatar
I see,
"Red" is kinda same of OEM stiffness, and "Blue" is more stiffer, correct..?
-;ZAYED;-
Old Jun 18, 2019 | 03:32 PM
  #63
raw1879's Avatar
Mercedes C55 AMG
Its hard to be consistent at the ring but it’s now easier with manual about 10sec a lap quicker
Old Jun 18, 2019 | 04:30 PM
  #64
C63 and CLK55
I see,
-;ZAYED;-
It is the opposite. Blue is softer than red. Even the blue is stiffer than OEM. PM me if you have any other questions, I'd be happy to help you. I just don't want to clutter up this thread. Thanks
Old Jun 18, 2019 | 09:15 PM
  #65
Quant's Avatar
2002 CLK55
great stuff, glad to see you got manual trans working. curious how much wheel horsepower changes as well.
p.s. i installed these ECE mounts, they are awesome. car feels a lot more solid, and actually less vibration then oem mounts. highly recommend them!!!
Old Jun 19, 2019 | 03:19 AM
  #66
raw1879's Avatar
Mercedes C55 AMG
The engine mounts are definitely my next mod just. Come on pay day
Old Jan 14, 2020 | 12:19 PM
  #67
Pagz's Avatar
C43 w/clk55 Organs
Originally Posted by raw1879
Hey, Did you have DLI-TEKNIK supply? any reason you didn't go with the Sachs 765 setup?
Old Jan 18, 2020 | 05:23 PM
  #68
Hooblah's Avatar
Merc
What's the part number for the flywheel?
Old Jan 19, 2020 | 04:38 AM
  #69
raw1879's Avatar
Mercedes C55 AMG
Old Jan 19, 2020 | 12:08 PM
  #70
Pagz's Avatar
C43 w/clk55 Organs
TTV racing?
Old Jan 19, 2020 | 01:04 PM
  #71
raw1879's Avatar
Mercedes C55 AMG
Originally Posted by Pagz
TTV racing?
yep
Old Mar 9, 2021 | 03:15 AM
  #72
kaixdiego's Avatar
190E, C36, C55, CLK55, ML55
is this the Rennsport Factory Flywheel? Also what clutch are you running? Hope you and the car are recovering well from your spill btw!
