C43 not charging, dont know why
Old Nov 18, 2018 | 08:02 PM
brad_c43's Avatar
'99 C43, '88 560SL
Hi all, car has a new altenator and a new battery but I have 11.2 v at the battery and the battery light is on. I tried swapping the relay in that k40 box and I tried grounding the altenator to the frame to see if it was a grounding issue but I dont know where to check next on why this car still has the battery light on.any sugestions on where to check next? Thanks!
Old Nov 19, 2018 | 12:08 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Start the car and then disconnect the battery. If the car dies then you have an issue with your alternator, if it continues to run then the problem is most likely with the battery. Even though both are new there could still be issues with them.
This is where I would start
Old Nov 19, 2018 | 12:12 AM
just found this
Old Nov 19, 2018 | 03:06 AM
DRBC43AMG's Avatar
Nice, I had forgotten about that trick
Fubabox has loads of How To videos.
Old Nov 19, 2018 | 11:35 PM
brad_c43's Avatar
'99 C43, '88 560SL
Turns out, while I was told this was a reman Bosch unit the reman parts were very cheap in quality. The voltage regulator is bad
