C36 head gasket
C36 head gasket
What part number are people using as of late for the head gasket? I searched, and came up with HWA 104 016 0120.
I called the dealer, they asked for my VIN, and this part number came up: 104 016 2820 and not the usual HWA 104 016 0120. The car is an authentic, 1995 c36 so there is no question there.
https://www.mbdirectparts.com/oem-pa...ket-1040162820
They assured me it is correct, however even the description is incorrect. Are they right?
Thank you!
Thank you!
I found some additional information with the bore diameter of the updated head gasket for generally other m104 engines of 104 016 2820 @ 91mm, and the head gasket for the 3.6L engine with a bore diameter of 92mm. Thoughts?
Has anyone used the 104 016 2820 gasket with success?
91mm bore
92mm bore
91mm bore
92mm bore
