My W202 blog and my new C43
Old Apr 26, 2020 | 12:08 PM
  #201
MBCLK60's Avatar
Originally Posted by PJmak
Looks insane man.
Whats it dropped on?
OEM cut springs and wrong shocks...seriously.
Already have new H&R Sport Springs and sourcing a new set of Bilstein.
Would you happen to have any recommendations for front / rear shocks?
The OEM/dealer setup is EXPENSIVE.
Thanks...
Old Apr 26, 2020 | 01:56 PM
  #202
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
Have Voghtland springs and Bilstein B2 sports.Rides great.
Old Apr 29, 2020 | 03:50 PM
  #203
PJmak's Avatar
Fresh rubber on. Hopefully not too much fitment issues.
18x8.5 225/40/18
18x10. 265/35/18
Old Apr 29, 2020 | 03:51 PM
  #204
PJmak's Avatar
Thanks...
This guy recomended these
Old Apr 29, 2020 | 07:01 PM
  #205
PJmak's Avatar
Itll be a tight fit. Might need to go down to 255s. Hope not
The wheel will naturally tuck in as the car is lowerred. Im hoping to drop it at least half way down without rubbing.
Old Apr 30, 2020 | 08:20 AM
  #206
MattCordell's Avatar
C43 AMG with a tune up
Your rear wide tires will spray grime all over the fenders and sides of the rear bumper and sandblast them clean from red paint.
Paint damage will probably be a huge headache for you?
Going wider than recommended is not always a good idea!
In the end it's your car and you may tweak the way you like it to be.
Good luck
Old Apr 30, 2020 | 07:24 PM
  #207
siideways's Avatar
22 X3, 21 330e, 97 M3, 97 C36 (sold), but on the hunt for a clean, low-mile C43!
This ain't no PS...my Obs Black is really this low...
Did you recently buy this car from that guy in Seattle?
Old May 1, 2020 | 10:58 AM
  #208
Beautiful wheels...PJ what are the specs on the wheels. Thanks!
Old May 1, 2020 | 11:00 AM
  #209
BTW...those coilovers look real nice.
Old May 1, 2020 | 11:20 AM
  #210
PJmak's Avatar
They are 18x8.5 and 18x10 ET25 all around
Old May 1, 2020 | 04:29 PM
  #211
PJmak's Avatar
Awaiting the final polish on the paint and to be put together.
Tried to drive it yesterda . Ut water pump pulley is rly loose so didnt wanna risk it.
Things ill be doing in the next few days weeks.
-waterpump coming next week so ill swap that
-paint was compounded but not polished yet
-found someone to repair my. Umper
-swap springs for lower ones
-irdered some leatherique and will hit the whole interior
-put all the trim and bits back together and im hoping the car will be in one piece soon
Old May 2, 2020 | 02:18 PM
  #212
PJmak's Avatar
Little teaser.
Old May 2, 2020 | 06:40 PM
  #213
PJmak's Avatar
Teazers
Old May 2, 2020 | 09:25 PM
  #214
PJmak's Avatar
Ok one more for now
Old May 3, 2020 | 10:29 AM
  #215
MBCLK60's Avatar
Beautiful PJ!
Just something about these cars...
Old May 3, 2020 | 11:41 AM
  #216
Goldecho's Avatar
1996 Mercedes C36 AMG
Beautiful PJ!
Ooo, those 3 are yours?
Old May 3, 2020 | 10:32 PM
  #217
PJmak's Avatar
My car is trying to tell me something with the hearth shaped rock chip.
Btw its nowhere near done but the front shot looks just right.
Old May 6, 2020 | 04:10 PM
  #218
PJmak's Avatar
Man this forum is deeeaaddd
Old May 6, 2020 | 04:28 PM
  #219
Goldecho's Avatar
We are a rare breed PJ. Your C43 is looking great. Rims are just right.
My C36 is getting some top end attention right now - head gasket, timing system/valvetrain inspection , water pump, even a new harness for good measure.
Old May 6, 2020 | 05:02 PM
  #220
PJmak's Avatar
Fair enough.
I will be doing a water pump as well, it should be arriving today.
Im looking into some coilovers so I can dial in the suspension to where its just right also.
Old May 8, 2020 | 04:07 PM
  #221
PJmak's Avatar
Replaced water pump and flushed coolant. Donot attempt this without proper tools youll be sorry. Spark plugs and valve covers next.
Old May 9, 2020 | 05:10 AM
  #222
DRBC43AMG's Avatar
Good going
At least it seems you didn't have a screw shear when dismantling. It happened to me and I had to remove the rad and A/C condenser to enable clear access for the use of a drill and stud extractor. Finally went OK. Changed the belt and tensioner when I was in there. It's very easy when you have access. Also I would strongly recommend checking the square oil pressure pick up point lurking there for possible leaks. Again something very easy to change when the pump, rad, etc are out.
Regarding the valve covers, I also recommend you change the spark plugs before reassembling the covers with new gaskets. Without the covers on you have a little more access to the plugs and tools and in that area, every bit of space is appreciated, specially your fingers and hands.
Old May 9, 2020 | 03:59 PM
  #223
PJmak's Avatar
Thanks man.
I replaced the belt and the idler pully. Should have done the tensioner as well but it seemed fine.
I napped the two screws on top that hold the metal plate bracket where the two sensors are.(these have nothing to do with the structural integrity of the pump). They dont come threaded so you have to screw the bolts in and form threads. About half way in each snapped.
Old May 10, 2020 | 10:21 AM
  #224
The_mabman_20's Avatar
Red 1995 C36
Looking good! I’ve been working on another project recently but back to the c36 this week.
Old May 11, 2020 | 11:00 PM
  #225
PJmak's Avatar
Owly putting the trim back on. Also put the door handles and one side side skirt on but the skirt will have to come off when the bew clips come in.
