Battery connector
In the box was supplied a quick fit connector.
Has anyone fitted a charger connector to the black box in the engine room so you can charge the battery, not using crocodile clamps on battery in trunk?
Had to borrow RAW's photo to highlight the black box
ps. It’s easy to turn off the trunk light if you leave it open overnight. There’s a pull function on the switch.
There are two pins in the black box, both seem to read positive as I measured with a multimeter.
I connected the quick-fit connector to positive pin on the left side inside black box and the negative wire was bolted under the washer fluid container to a ground where other 5 ground wires are connected.
I hope this modification doesn't fry any electronics?
What does MB-technicians say about this modification?
Is it safe or not to charge battery from this position in the engine bay?
To the left one of the terminals have 2 thinner wires, the second terminal on the right has a thicker wire.
I assume both are positive?
